Lenilenapi
Carbonite Member
Your basic choice is Canon EF or Nikon.
One advantage of Nikon is that you can always adapt a Nikon lens to a Canon mount but not vice versa. However there are other considerations
None of these apply to Rokinon primes though because those lenses have mechanical irises without hard stops ( cine version anyway) and no IS. However there are real pros and cons to Zooms.
Pros of Nikon:
- All Nikon lenses even those without iris rings ( G lenses) can couple to a G adapter that has a mechanical coupling to the actual iris. This allows you to smoothly rack iris while shooting video without any stepping or needing to go into menus . Depending on the adapter you probably won't be able to see what your f-stop is and the control might be pretty loosey-goosey but it sure beats riding iris in 1/3 step increments.
- Seems to me its easier to get good quality Nikon zooms ( esp older ED glass ones) that are roughly parfocal at great prices. I've had 5 Nikon zooms that are all parfocal. Harder to find in Canon. But sometimes that requires being able to adjust the back focus of the camera - I could do it on an F3 but i don't think you can on FS7. However I think you can with with Speedbooster.
- Even if you went with an EF adapter , you can always put a Nikon lens in by coupling to a Nikon> EF adapter first.
Cons of Nikon
- Focus barrel turns the opposite way from standard and that can be confusing.
- No one makes a Nikon adapter that carries power so none of them will activate image stabilization, auto focus and you can't adjust iris in the menus which you might want to do with G lenses.
Pros of EF
- Many adapters power the Image Stabilization which is a very big deal to me
- Focus barrel is standard
- Because of the popularity of Canon DSLR's, EF lenses are even more common than Nikon among the video community.
Cons of EF
- all Iris's on zooms are electronic and therefore have stops. Maybe 1/6th stop if your lucky but not smooth.
I have all Nikon for my F3 but am considering going to EF for the FS7 because the EF to E adapters can activate Image Stabilization.
I might keep some Nikons though and just adapt them over to the EF mounts. I'll try it first anyway and see if its wanky.
I would like all my focus barrels to turn in the same direction though.
lenny
Pros of Nikon:
Cons of Nikon
Pros of EF
Cons of EF
lenny
