Joe Walker
Hey all,
For those in the know on the new Sony F3, I have a few new questions to ask:
1. The PL mount; is it strong enough to hold A) Zeiss Compact Primes B) Cooke Panchro/S4i C) Angenieux Rouge zooms/Zeiss Lightweight zooms WITHOUT support and if so how is that possible? Or (in other words) is this pl mount stronger/better than the hotrod pl on the AF100?
2. Playing devil's advocate here, but if one were to purchase/rent/use the upcoming SR-R1 off-board recorder using the dual link and s-log, what is the workflow like for an FCP editor? Same question but for CS5 Premiere? I'm talking from ingest to output.
3. The 64GB SXS cards; I see that they are not the "Pro" version like the 32GB ones. I was reading that they are not rated to last as long. I've run into this with Panasonic's E-series P2 cards and have found that in most cases, you are fine with the shorter life span cards but I was curious does anyone else have experience with this issue? Has anybody been able to wear out a 64GB SXS card in a very short period?
Thanks, look forward to the answers.
