starcentral
Sony is at it again, announced yesterday is a new filter option (CBK-55F2K) which according to sony will allow you achieve a more "softer, more organic image" when in 4k or 2k RAW mode.
I wonder if this is like 1/4 Hollywood Blackmagic filter to give more "ARRI Alexa" like appearance?
There is some speculation this is to reduce moire and aliasing, but nothing formally released or details given by Sony.
From scouring the Sony forums it seems really its a filter (OLPF) optimized more for 2k RAW shooting, but can be used when shooting 4k mode as well for a "softer" image.
I suspect the timing of this release comes for when 2k RAW mode shooting becomes available via firmware later this month.
http://www.xdcam-user.com/2013/09/a...s700-pmw-f5-pmw-f55-and-others/#comment-35316
Reading between the lines (ha ha) the cam(s) 55/5/700 is not performing well at 2k raw. (we have seen clues of this) this is kind of to be expected as the filter should soften the res to just above the res of the sensor - change the res and you must change the filter - makes perfect sense.
Now it seems like it is going to add a level of complexity to operation probably each project you would undertake with a filter. So is your project 4k60p (drama) or 2k/240p - corporate/event/pop vid ?
Slightly more annoying is the S16 mode will probably look a bit too soft with the stronger filter (like Red!) - yet the S16 mode hits the 'corp/event/pop vid' sweet spot
I think we now have three cameras..!
4k dramacam
2k corp pop cam
16mm eng cam
Great - but you will need to know which you are taking out in the morning IMO!
S
HFR in center crop mode will not have this issue, as there is no pixel binning happening in that case.
Im not buying this casual attitude myself.
Bottom line is that if you are shooting a Serious Corporate Mr Shirt or his expensive corporate brick HQ, your footy is going wonko if you shoot 2kRaw
Dinking with front of lens filters is a good reason to stick with the FS100 or buy a BMC if front of lens filters were my thing - they are not - way too slow
Sony didnt make the filter for fun.
Edit replying to wrong thread
The only 'mishap' is if the 700/Ody delivers better HD (by4kcompressed+downscaling) than the naked5 using an onboard codec and of course the 700/ody does actual 4k too!
S
