For Joy's shots, did you shoot 1080 or 720? Whenever I shoot 720p with a letus, and my nikon glass, I'm always critical of the softness of the image. But your shots looked amazingly sharp.
Did you do anything with the light on her shots? Or was the light naturally that beautiful?
6x6 Grip Silk
2 4ft 4 bank Kinos bulbed daylight no egg crates.
I shoot almost everything 720PM unless it's going to be green screened or roto-ed
Lenses are just vintage Nikkors nothing special... admittedly not hard to hold focus as the camera didn't move... as I was the only crew I was hedging my bets - focus-wise.
Really? I didn't know Kinos would be able to compete with daylight. Did you have a generator? Did you use the silk to diffuse the sunlight, then use the kinos to fill? How far away were the kinos from her?
I probably have the same lenses as you, old Nikkors passed down from my dad. Sharp as can be when I shoot stills on 35mm. But when I use them on the letus/HVX, the footage doesn't look as sharp as yours. For instance: http://vimeo.com/3822372
I shoot mostly wide lenses so I was real close to her.. 2 to 3 feet... I did shoot the 105 to hide the lack of green.
Yes... the grip silk turned the sun into my key and the Kino's we're fill... about 3.5 ft away.. a Wall O Light or 8 4 foot bulbs will give you some fill.... especially because I was kind of in the shade.
In general I try to keep the camera at an f5.6 and the Letis/Nikkors at a 4... that combo gives me the best sharpness without seeing the vibrating ground glass of the Letus
So was the whole thing shot with your Nikkors at f4? You looked like you got pretty shallow DOF.
Sorry to keep asking questions. But what lenses did you use for each of her shots? The wide looked like a 24, the ECU looked like a 105.. Is that right? Both at F4? What about the Medium and CU?
The wide was a 17mm... some off brand I was given for free... bad except for music vids because of excessive port holeinf.
50mm and 105.
f4 is where I TRY to keep it... I probably opened up a bit on the 50.. as I said I was trying to hide the lack of green... neither lens are usual for me... but the situation called for those lenses. 35 is about a long a lens as I get when I'm in charge
