HD-tography
New Condition
13.2 lb (6kg) Load Capacity,
Aluminum Legs,
17.1" to 65.1" Range,
Fixed Counterbalance,
Variable Teflon Drag System,
75mm Half Ball,
Mid-level Spreader,
Manfrotto MBAG80N Tripod Bag
BONUS: EXTRA 501HLV Pan Handle! (29.99 Value)
Price: $450 + 3% PayPal Fee (Or Send Money As Gift) + Actual Shipping to ConUS, Canada, and some places in Europe (PM me for shipping quote)
Shipped From North American Location (Canada) The Day Following Cleared Payment
I only accept PayPal
Also Check My Other Items For Sale, Massive Liquidation Of New & Like New Professional Camera & Cinema Gear! Everything Must Go!
To See More Detailed Photos Of This Sale Visit:
http://photobucket.com/Manfrotto501HDV546bTripod
To See Even More Photos Of This Massive Sale Visit:
http://photobucket.com/TheGreatLiquidation
The Manfrotto 501HDV Head w/546B 2-Stage Aluminum Tripod System combines the workhorse 501HDV Pro Video Head with a 75mm half ball and the 2-stage aluminum 546B Pro Video Tripod--bringing affordability, stability, and light weight into one sturdy package. Inspired by Manfrotto's top pro systems, this compact combo provides the support and smooth, fluid action demanded by today's videographers and DSLR shooters.
501HDV Fluid Video Head
Designed to accommodate evolving video technology, the 501HDV features improved drag in both axes and switchable counterbalance for the latest ultralight HD camcorders and DSLRs. Controls are positioned and shaped for superior operational ergonomics, while a sliding camera plate helps balance uneven payloads due to outboard batteries or other accessories. Dual rosettes permit left- or two-handed pan arm configurations, with a rear-mounted spirit level facilitating rapid setups.
546B Tripod
This aluminum two-stage tripod combines stability and strength with affordability. Reaching a maximum height of 60.6" (154cm), the 546B is capable of supporting up to 44 lbs (20kg). Its spiked feet come with rubber overshoes, allowing setups on both smooth floors and uneven surfaces, while a mid-level telescopic spreader keeps the legs exactly where you need them.
General
Load Capacity 13.2 lbs (6kg)
Maximum Height 65.1" (165.4cm)
Minimum Height 17.1" (43.5cm)
Folded Length 31.7" (80.5cm)
Leveling Bubble
Weight 11.2 lbs (5.1kg)
Head
Counter Balance System (Fixed Spring)
Quick Release/Wedge Plate
Sliding Balance Plate w/58mm of Travel
Tilt Drag 1-Step
Tilt Range -60° / +90°
Tilt Lock Independent
Spring Loaded Counter Bal 1-Step
Pan Range 360°
Pan Lock Independent
Legs
Material Aluminum
Head Attachment Fitting 75mm Bowl
Leg Stages/Sections 2/3
Leg Lock Type Flip Levers
Independent Leg Spread Yes
Spiked/Retractable Feet Yes w/rubber covers
Center Brace Mid-level Spreader
Manfrotto MBAG80N Tripod Bag:
Ballistic Nylon Bag
Padded End Cap
Zipper Extends the Entire Length
Shoulder Strap
The Manfrotto by Bogen Imaging MBAG80N Tripod Bag (Black/Red) is a ballistic nylon bag designed to carry Manfrotto tripods with head up to 31" long. The end cap is padded to offer protection to the tripod head. The zipper extends down the length of the bag, but also fully opens the top end of the bag. The end opening allows for faster "quiver" style extraction and insertion of the tripod.
The tripod legs fit comfortably in the narrower end and extra space is allowed for the larger volume of the head at the wider end. This also means it's easier to put the tripod and head in the bag, even if the head levers and knobs are fitted and jut out slightly. The bag includes a shoulder strap.
Construction
Ballistic nylon
End cap is padded to offer protection to the tripod head, the rest of the bag is unpadded
Full length zipper
Bag is slightly tapered to provide a better fit for a tripod with the head attached. The wider end of the bag accommodates the head without requiring all levers to be removed
Carried by the attached shoulder strap
Compatible with Manfrotto tripod with head up to 31" long
