Here are some frames exported from Adobe premiere (i know the aspect ratio is not correct, its supossed to be 16:9)
Today is the big day, iam going to shoot this with 5 actors on te table (this was just a test) and while i dont have anymore time to test the lighting, iam still VERY VERY VERY curious about your opinions! So i hope to hear some reactions without the next hours
Iam a bit nervous about this, because it looks -on a t.v.- very grainy.
I did NOT use the gain setting, i shot it with 0 db.
I had enough exposure (but even if i did not have enough light: the gain was off, so why should there be any gain? it must just get black!!)
I expososed the scene for the brightest object in the room (the lamp) So i lower the exposure untill there was no overexposure on the table caused by the lamp. Therefore, the rest of the room was getting a lot darker but the bright object appeard fine.
It was the look i wanted.
But playback on a tv its grainy and moving.
It was shot with a DVX100b scene file 6,
no changes made.
(unless for exposure and manual WB)
So, what can i do? because: when you shoot something brighter/overexposed than the rest in the frame and you lower exposure to make it look right, the rest of the frame gets darker.
But is it normal to have grain with it also?
There was enough light, i closed the lens, so why is there gain?
Anyways: even if you dont have a answer, please leave a comment on the lighting.
no changes made.
