New GF1 v1.24 and GH1 v1.34 firmware hack problems
I'm become more and more convinced that if your GH1 camera is supplied with Panasonics Ver 1.3 firmware you will NOT be able to use PTool to hack the firmware.
The camera was bought in the UK from Currys - two weks ago and the Cameras SET UP reports Camera Body Ver1.3 and it is proving impossible to update the firmware with PTool.
It could be possible that Panasonic are installing new versions of the firmware (say Ver1.33 which traps Hacked updates) - this is possible.
In order to disprove this I need just one member to confirm that thay have been able to use Ptool with a factory installed Ver1.3 firmware.
One member says that all cameras are released with Ver1.2. Does anyone else have a camera with a factory installed Ver1.3?
Sorry but I seem to have two threads running on this topic - apologies
DIB
try to hack with version increment for 3 and prevent version compare checked, file name 135
【HELP】newly bought GF1 with ver【1.24】 can't update the hacked firmware【HELP】
The Japanses version GF1 which I bought this week has been installed an original ver.1.2 firmware in factry,so it can not be updated with the unlocked firmware made by ptool3.
I've tried the number -1,0,1,2,3,4 in version increment blank,but it doesn't work.
Please help me!
It made me crazy:violent5:
7.12 add on:
In the engineer mode I found my gf1's firmwork version is 2.14!
So all hacked 1.22 firmworks can't be updated.
And there's NO ver 2.14 to download now.....
It's so tempting to post the following link, but I won't:
http://www.dvxuser.com/V6/showthread.php?t=216313
I'm starting to understand this thread a lot more then I did the day it was posted.
I have a problem with this statement because, as I already said...
I also have a brand new GH1 and it hacked fine following the directions.
Brand new meaning a week old from B&H. Honestly if you're fighting it that much can you either return the cam (if you can) or try to accept it as it is...(?)
At least right now you have a working camera...
I updated to 1.32 and then to the hack firmware. No problems at all. I read in some other thread where people installed the official 1.33 and were still able to hack too.
If someone could sort the camera out I would be more than happy to donate to tester13. Bit of a difficulty in sending the camera from the UK to Florida and back again.
I've tried every suggestion posted and still get the message 'NO VALID PICTURE TO PLAY'. I've even tried a bin file emailed to me and that also did not work. I've tried different SD cards, different computers, many many different version nuimbers from 1 up to 15 with filenames from GH1__133.bin to GH1__142.bin. Battery fully charged, reformatted SD card, in the root folder, PTool v3.36, v3.37d and 3.40d, etc, etc
I realise that members can update if they start off with Ver 1.2 my problem is that the camera arrive from Panasonic with Ver 1.3 installed.
I'm still looking for other members to say that they started with a factory installed Ver1.3 and have been able to use PTool successfully. (so far only one member thinks he may have done this)
DIB
Just as a neutral observer of all this, I have to say I'm skeptical that you have a super special unhackable camera. Even if yours is one of very few shipped from factory with 1.3, it's hard for me to image that the factory installed 1.3 would be different from any of the 1.3x updates that are out there.
You've said you're an experienced computer person, so the approach I would take would be one that is helpful whenever a programmer has a bug that can't be tracked down.
(1) Relax. Go back to square 0.
(2) Describe for someone else each and every step you're taking in your update process. It's important to include even details that you might not think are important or relevant.
(3) Usual result is that (a) in process of re-describing you discover for yourself what the problem is, or (b) with more detailed description someone else will be able help.
Of course it is _possible_ that you are the only person out there with an unhackable camera. The odds of that seem quite low, however, so going back to square zero seems like next best step. You may feel like you've already gone back to squre zero several times. Maybe you have. But doing it again (and maybe again and again, each time taking note of more and more supposedly unimportant or irrelevant details) may still help. Important thing is to relax and to adopt a mindset of beginning again, forget everything you've done before and explain it like you're explaining to a child.
In computer programming and in system administration it's totally common to _feel_ like you've done everything perfectly, like it must be something special about the system because it can't be you. The vast majority of the time it's not the system, it's something, often something very simple and basic, that has been overlooked and/or misunderstood.
here we go AGAIN.
FIRST.
Format your card in camera.
SECOND.
Load panasonics firmware in Ptool.
•CHECK VERSION INCREMENT
•AT THE BOTTOM CHANGE THE NUMBER 1 TO 50 (This is just in case Panasonic shipped you camera post-hacked)
•CHECK PREVENT VERSION COMPARE
THIRD
•Click Save firmware
•Save the file in the same directory as your panasonic firmware and click on it
•Don't overwrite, just change the 1.32 to 1.33 your file should now look like GH1__133
•Save
FOURTH
•TRANSFER YOUR NEWLY HACKED FIRMWARE TO THE CARD YOU FORMATTED IN CAMERA. JUST DRAG ONTO THE CARD, DON'T PUT IT IN ANY OF THE FOLDERS.
FIFTH
•MAKE SURE YOUR CAMERA IS OFF, AND LOAD THE CARD INTO CAMERA.
•TURN CAMERA ON AND PRESS PLAY.
•ONCE THE FIRMWARE IS LOADED, CHECK YOUR VERSION. IF IT SAYS 0.0, SUCCESS.
•FROM NOW ON, DO NOT CHECK VERSION INCREMENT, ONLY PREVENT VERSION COMPARE
here we go AGAIN.
Car3o -- If your repost of the steps is in response to my message above, I would just clarify that I think it's important for dvxdib to go back to square zero, not for _someone else_ to re-provide the steps. Assuming that the camera is hackable, it must be something very basic dvxdib is missing, potentially something so basic that is being left out of every recitation of steps. . . .
Hi. I too get the message "No Picture.." I can't do anything to fix it. Also, camera is does not shut down (it will only take three stills) or allow me to record film mode. About the only thing it can do is focus and go through menus.
It all started when I was moving up from 3.37 hack. I can't get back to factory settings. It seems like the system is shut down and won't read what's on card.
guys, if you get "No Picture" its' because you have a firmware on your card and need to delete it. format the card and try taking pictures and record again.
don't you have to update to panasonic 1.32 firmware first? thats what I did to my GH1 before I even tried the hack.
The latest version of GF1 is 1.24 which is installed in factory,I can’t update by original 1.22 firework or the hacked one
Many thanks.
Actually I am a C program software developer, over 20 years experience. I have gone back to basics and still cannot get it to work.
Hi dvxdib
I've got exactly the same problem as you, bought the camera in London a week ago, was depending on getting the hack and now everything you've experienced, I have too. What's more is that my camera also says version 1.3
Here is the thread where I asked for help
http://dvxuser.com/V6/showthread.php?t=216281&page=1
Let me know if you've any new ideas/solutions - hopefully we can help each other out!
