Very interesting. What power supply are you using with it? Do you have a picture of the cabling from the LED mats plugged into the DMX box?
Falconeyes is killing it! There are RGB version is out now. Can't wait to see all the rebrands charge $1400 for the same light, and try to convince us it's different.
Wish I had your tinkering skills Noah! You have a source already for your strips?Yeah saw those pop up on AliExpress a week ago and seems interesting. Kinda pricey though, and seems somewhat lower output plus it doesn't seem to offer much in the way of gui or programs though I guess that's left to a DMX controller. I'd frankly have a little trouble getting behind it for the price given the falconeyes build quality but great to see the options are moving along.
I've moved on a bit trying to build a modular portable flexible led light/system hoping to beat skypanels s60c output for under $500. Seems pretty feasible to do with flicker free DMX drivers capable of running 1kw of LEDs going for only $80. For a while that was the limiting factor since finding high khz pwm controllers off the shelf was not trivial, nor was finding affordable high critical high output led strips. About to test out some 95+ cri 100w led strips. I figure I'll put together 200w of daylight, 200w of tungsten and 200-400w of RGB in separatable or gangable units and make flex lights I can shape in to a variety of form factors or possibly also use as linear tubes. Still working out the best approach.
Trying these out in tungsten and daylight: https://www.amazon.com/dp/B073WVJSB...r 45 bucks. I may have to plat with these...
Thanks for the pics, the ballast looks much smaller.Check with them that they are sending the latest version.
http://s.aliexpress.com/7fYziQ7J
Trying these out in tungsten and daylight: https://www.amazon.com/dp/B073WVJSBY/ref=cm_sw_r_cp_apa_84glBb06FKHF7
Almost bought similar ones on AliExpress until I saw they were only $1 more on Amazon shipped in 1-2days with prime. Hope they live up to specs.
Just received them and only plugged them into a 24v power supply. They actually came wired to plug right into a power supply. I may just use them bare on some jobs until I have time to combine all of the strips together and built a RGBWA unit.
They do seem to have serious output but I don't have a spectrometer to confirm cri ratings. May try some tests on my new red gemini to make sure they don't have any green casts and look ok on skin, just have to find the time...
I mean just the idea that one of those $45 strips plugged into a $15 power supply should have the same output and color as the already amazing rx18td or rx-29tdx but be easily hung or shaped into a softlight or stuffed in a softbox is pretty interesting.
