New Firmware June 1st.
Jason Davenport
info from: Greg Penetrante Dvinfo
Here from Sony...
INTRODUCTION OF THE NEW CBK-RGB01 4:4:4 RGB AND S-LOG OUTPUT OPTIONAL SOFTWARE FOR PMW-F3K/L
TYPE: INTRODUCTION
Sony is pleased to announce the introduction of the CBK-RGB01 Optional Firmware Upgrade for the
PMW-F3 XDCAM EX 35mm Camcorder. This new upgrade enables the following functions:
1. S-Log gamma
2. 3G-SDI output
3. Dual Link RGB444 video output
4. User LUTs
5. Pre-loaded LUTs
RGB 4:4:4 Output
RGB 4:4:4 1080 23.98/ 25/ 29.97PsF signal is available over an HD-SDI dual-link interface or 3G HD-SDI
output (menu defined), allowing the use of an external recorder such as the SR-R1 SRMemory Recorder
for the highest quality output for VFX works such as Chroma-key, compositing, and CGI. The Dual Link
HD-SDI option enables 10-bit RGB 23.98/25/29.97PsF or 10 bit 4:2:2 108050P/59.94P uncompressed
external recording – ideal for integration with high quality production workflows such as HDCAM SR.
S-Log Gamma
S-Log mode is available with a wide dynamic range (800%) in the RGB 4:4:4 10-bit signal.
Built in LUTs
Retain the maximum dynamic range from shadow details to highlight. Exactly the same S-Log workflow
as for high-end products such as the Sony F-35.
LUT (Look Up Table)
LUTs can be applied to HD-SDI output and SxS recording off-line. User-defined LUTs (created by CVP
file editor) can be stored by using an SxS card. LUTs can be used for off-line edit with the SxS
recorded content. Users can also transfer user-defined LUTs from one camera to another for ease of
set up.
This new software upgrade option requires the installation of v1.10 operational firmware for the PMWF3K/
L. The PMW-F3K/L v1.10 firmware is user installable via an SxS card, and downloadable, along with
instructions, from the Sony ServicesPlus website: (link didn't work)? (or see it listed?) JD
List Price Qty Available
CBK-RGB01 - 4:4:4 RGB and S-Log output option software for PMW-F3K/L $ 4,440 - 1 June, 2011
Features and specifications are preliminary and subject to change without notice.
No this is not the S-log, this is just the free update, Slog is listed for $4,000
