Martti Ekstrand
If you transcode your finished project you will have trouble doing proper pulldown removal. Some shots with look right and others will have interlacing artifacts and/or jittery motion.
Luckily I'm in PAL land so don't have to deal with that pulldown silliness. I'd venture as far as to say that even in US if you aim for some sort of cinema release you might be better off using a PAL GH1 shooting 25 for 24 and deal with the 6% slowdown in the last stage. That's a artifact which a general audience notices a lot less than interlace errors.
As for ProRes, it does add sharpening artifacts. It might not be as noticeable on footage from HMC150 as on GH1. It's certainly noticeable on 35mm or CGI originated footage compared to lossless codecs especially when moving gamma point, forcing contrast or upping saturation. For commercials I've never used ProRes for final post, CC and effects but opted for a lossless codec. In my opinion it would have been better for film makers if Apple had built on PhotoJPEG instead and expanded it's real-time capacities in FCP but then they wouldn't have a proprietary codec to control and use as a selling point. I've hacked FCP's "RT Software Enabler" settings file to enable full SD PJPEG playback with real-time effects - haven't gotten around yet to see if I can do it for 720 or 1080 yet but will report back when I do.
When I tried various transcoding methods for GH1 footage I did notice that the Cineform files looked more like how the original looked in Toast Video Player than ProRes and could be pushed just a little bit more in CC. Not surprising as with ProRes you add one DCT compression method on top of a variation of DCT while Cineform uses wavelet compression which has less of a tendency to sharpen edges in the material. PhotoJPEG was somewhere in between and with smaller file sizes than either one.
For obvious reasons I have yet to check out the new variants of ProRes so can't speak on their quality yet. The tools I used were FCP, Toast, Voltaic and NeoScene. Test for yourself to see what adds the least amount of flies to your ointment is my advice - this is a area highly influenced by individual setups, methods, footage content and gut feeling.
