https://www.dji.com/dji-action-2/specs
This looks interesting. Wonder how the image quality will be in comarison to something like the GoPro Hero 9/10 Black
General
General
- Dimensions
- 39×39×22.3 mm
- Waterproof
- 10 m without Waterproof Case, 60 m with Waterproof Case
- Number of Microphones
- 1
- Weight
- 56 g
- Touchscreen
- 1.76 inches 350 ppi
500±50 cd/m² 446×424
- Sensor
- 1/1.7” CMOS
- Lens
- FOV: 155° f/2.8
- ISO Range
- Photo: 100-6400
Video: 100-6400
- Electronic Shutter Speed
- Photo: 1/8000-30 s
Video: 1/8000 s to the limit of frames per second
- Max Photo Resolution
- 4000×3000
- Zoom
- Digital Zoom
Photo: 4x
Video: 2x (> 60fps), 3x (≤ 60fps, HorizonSteady On), 4x (≤ 60fps, HorizonSteady Off)
Slow Motion/Timelapse: Not available
- Still Photography Modes
- Single: 12 MP
Countdown: Off/0.5/1/2/3/5/10 seconds
- Video
- 4K (4:3): 4096×3072 @ 24/25/30/48/50/60fps
4K (16:9): 3840×2160 @ 100/120fps
4K (16:9): 3840×2160 @ 24/25/30/48/50/60fps
2.7K (4:3): 2688×2016 @ 24/25/30/48/50/60fps
2.7K (16:9): 2688×1512 @ 100/120fps
2.7K (16:9): 2688×1512 @ 24/25/30/48/50/60fps
1080p (16:9): 1920×1080 @ 100/120/200/240fps
1080p (16:9): 1920×1080 @ 24/25/30/48/50/60fps
- Slow Motion
- 4K: 4x (120fps)
2.7K: 4x (120fps)
1080p: 8x (240fps), 4x (120fps)
- Timelapse
- 4K/2.7K/1080p
Intervals: 0.5/1/2/3/4/5/6/7/8/10/13/15/20/25/30/40 seconds
Duration: 5/10/20/30 minutes, 1/2/3/5 hours, ∞
- Stabilization
- EIS: RockSteady 2.0+HorizonSteady
* EIS is not supported when recording at 100fps or above. HorizonSteady is only available when the video resolution is 1080p (16:9) or 2.7K (16:9)
- Max Video Bitrate
- 130 Mbps
- Supported File Formats
- exFAT
- Photo Format
- JPEG / RAW
- Video Formats
- MP4 (H.264 / HEVC)
- Supported SD Cards
- microSD (Max. 256GB)
- Recommended microSD Cards
- DJI Action 2 supports up to 256GB SDHC/SDXC UHS-I Speed Grade 1 or Speed Grade 3 microSD cards
Recommended models:
Samsung EVO 32GB UHS-I Speed Grade 1 microSDHC
Samsung EVO Plus 32GB UHS-I Speed Grade 1 microSDXC
SanDisk Extreme 64GB V30 A2 UHS-I Speed Grade 3 microSDXC
SanDisk High Endurance 32GB UHS-I Speed Grade 3 microSDXC
SanDisk Extreme Pro 32GB UHS-I Speed Grade 3 microSDXC
SanDisk Extreme 16GB UHS-I Speed Grade 3 microSDXC
Lexar 633x 16GB UHS-I Speed Grade 1 microSDHC
- Audio Output
- 48 KHz; AAC
- Type
- LiPo 1S
- Capacity
- 580 mAh
- Energy
- 2.23 Wh
- Voltage
- 3.85 V
- Operating Temperature
- 0° to 40° C (32° to 104° F)
- Charging Temperature
- 5° to 60° C (41° to 140° F)
- Operating Time
- 70 minutes
* Tested in a laboratory environment while recording 1080p/30fps (Power Reserve) video with electronic image stabilization disabled. This figure should be used for reference only
- Wi-Fi Operation Frequency Range
- 2.400-2.4835 GHz
5.150-5.250 GHz
5.725-5.850 GHz
- Wi-Fi Protocol
- 802.11 a/b/g/n/ac
- Wi-Fi Transmit Power (EIRP)
- 2.4 GHz: <16 dBm (FCC/CE/SRRC/MIC)
5.1 GHz: <14 dBm (FCC/CE/SRRC/MIC)
5.8 GHz: <14 dBm (FCC/CE/SRRC)
- Bluetooth Operation Frequency Range
- 2.400-2.4835 GHz
- Bluetooth Transmit Power (EIRP)
- <4 dBm
- Bluetooth Protocol
- BLE 5.0
General
- Dimensions
- 39×41.6×24.6 mm
- Waterproof
- Not waterproof without Waterproof Case, 60 m with Waterproof Case
- 3
- Weight
- 64 g
- Touchscreen
- Battery Type
- LiPo 2S
- Capacity
- 1300 mAh
- Energy
- 5 Wh
- Voltage
- 7.7 V
- Operating Time
- Camera Unit + Front Touchscreen Module: 160 minutes
- Charging Time
- Camera Unit + Front Touchscreen Module: 90 minutes
* Tested in a laboratory environment when using a 5V/2A USB adapter
General
- Dimensions
- 39×41.6×21.4 mm
- Waterproof
- Weight
- 56.6 g
- Battery Type
- LiPo 2S
- Capacity
- 1300 mAh
- Energy
- 5 Wh
- Voltage
- 7.7 V
- Operating Time
- Camera Unit + Power Module: 180 minutes
- Charging Time
- Camera Unit + Power Module: 90 minutes
