new DJI action 2 cam
firehawk
https://www.dji.com/dji-action-2/specs
This looks interesting. Wonder how the image quality will be in comarison to something like the GoPro Hero 9/10 Black
  • Dimensions
  • 39×39×22.3 mm
  • Waterproof
  • 10 m without Waterproof Case, 60 m with Waterproof Case
  • Number of Microphones
  • 1
  • Weight
  • 56 g
  • Touchscreen
  • 1.76 inches 350 ppi
    500±50 cd/m² 446×424
Camera
  • Sensor
  • 1/1.7” CMOS
  • Lens
  • FOV: 155° f/2.8
  • ISO Range
  • Photo: 100-6400
    Video: 100-6400
  • Electronic Shutter Speed
  • Photo: 1/8000-30 s
    Video: 1/8000 s to the limit of frames per second
  • Max Photo Resolution
  • 4000×3000
  • Zoom
  • Digital Zoom
    Photo: 4x
    Video: 2x (> 60fps), 3x (≤ 60fps, HorizonSteady On), 4x (≤ 60fps, HorizonSteady Off)
    Slow Motion/Timelapse: Not available
  • Still Photography Modes
  • Single: 12 MP
    Countdown: Off/0.5/1/2/3/5/10 seconds
  • Video
  • 4K (4:3): 4096×3072 @ 24/25/30/48/50/60fps
    4K (16:9): 3840×2160 @ 100/120fps
    4K (16:9): 3840×2160 @ 24/25/30/48/50/60fps
    2.7K (4:3): 2688×2016 @ 24/25/30/48/50/60fps
    2.7K (16:9): 2688×1512 @ 100/120fps
    2.7K (16:9): 2688×1512 @ 24/25/30/48/50/60fps
    1080p (16:9): 1920×1080 @ 100/120/200/240fps
    1080p (16:9): 1920×1080 @ 24/25/30/48/50/60fps
  • Slow Motion
  • 4K: 4x (120fps)
    2.7K: 4x (120fps)
    1080p: 8x (240fps), 4x (120fps)
  • Timelapse
  • 4K/2.7K/1080p
    Intervals: 0.5/1/2/3/4/5/6/7/8/10/13/15/20/25/30/40 seconds
    Duration: 5/10/20/30 minutes, 1/2/3/5 hours, ∞
  • Stabilization
  • EIS: RockSteady 2.0+HorizonSteady
    * EIS is not supported when recording at 100fps or above. HorizonSteady is only available when the video resolution is 1080p (16:9) or 2.7K (16:9)
  • Max Video Bitrate
  • 130 Mbps
  • Supported File Formats
  • exFAT
  • Photo Format
  • JPEG / RAW
  • Video Formats
  • MP4 (H.264 / HEVC)
  • Supported SD Cards
  • microSD (Max. 256GB)
  • Recommended microSD Cards
  • DJI Action 2 supports up to 256GB SDHC/SDXC UHS-I Speed Grade 1 or Speed Grade 3 microSD cards
    Recommended models:
    Samsung EVO 32GB UHS-I Speed Grade 1 microSDHC
    Samsung EVO Plus 32GB UHS-I Speed Grade 1 microSDXC
    SanDisk Extreme 64GB V30 A2 UHS-I Speed Grade 3 microSDXC
    SanDisk High Endurance 32GB UHS-I Speed Grade 3 microSDXC
    SanDisk Extreme Pro 32GB UHS-I Speed Grade 3 microSDXC
    SanDisk Extreme 16GB UHS-I Speed Grade 3 microSDXC
    Lexar 633x 16GB UHS-I Speed Grade 1 microSDHC
  • Audio Output
  • 48 KHz; AAC
Battery
  • Type
  • LiPo 1S
  • Capacity
  • 580 mAh
  • Energy
  • 2.23 Wh
  • Voltage
  • 3.85 V
  • Operating Temperature
  • 0° to 40° C (32° to 104° F)
  • Charging Temperature
  • 5° to 60° C (41° to 140° F)
  • Operating Time
  • 70 minutes
    * Tested in a laboratory environment while recording 1080p/30fps (Power Reserve) video with electronic image stabilization disabled. This figure should be used for reference only
Connection
  • Wi-Fi Operation Frequency Range
  • 2.400-2.4835 GHz
    5.150-5.250 GHz
    5.725-5.850 GHz
  • Wi-Fi Protocol
  • 802.11 a/b/g/n/ac
  • Wi-Fi Transmit Power (EIRP)
  • 2.4 GHz: <16 dBm (FCC/CE/SRRC/MIC)
    5.1 GHz: <14 dBm (FCC/CE/SRRC/MIC)
    5.8 GHz: <14 dBm (FCC/CE/SRRC)
  • Bluetooth Operation Frequency Range
  • 2.400-2.4835 GHz
  • Bluetooth Transmit Power (EIRP)
  • <4 dBm
  • Bluetooth Protocol
  • BLE 5.0
Front Touchscreen Module
General
  • Dimensions
  • 39×41.6×24.6 mm
  • Waterproof
  • Not waterproof without Waterproof Case, 60 m with Waterproof Case
  • 3
  • Weight
  • 64 g
  • Touchscreen
Battery
  • Battery Type
  • LiPo 2S
  • Capacity
  • 1300 mAh
  • Energy
  • 5 Wh
  • Voltage
  • 7.7 V
  • Operating Time
  • Camera Unit + Front Touchscreen Module: 160 minutes
  • Charging Time
  • Camera Unit + Front Touchscreen Module: 90 minutes
    * Tested in a laboratory environment when using a 5V/2A USB adapter
Power Module
General
  • Dimensions
  • 39×41.6×21.4 mm
  • Waterproof
  • Weight
  • 56.6 g
Battery
  • Battery Type
  • LiPo 2S
  • Capacity
  • 1300 mAh
  • Energy
  • 5 Wh
  • Voltage
  • 7.7 V
  • Operating Time
  • Camera Unit + Power Module: 180 minutes
  • Charging Time
  • Camera Unit + Power Module: 90 minutes
Oops forgot to put the price: $519 USD
DJI Action 2 Dual-Screen Combo
USD $519
  • Versatile Magnetic Design
  • Portable & Wearable
  • 4K/120fps & Super-Wide FOV
  • HorizonSteady
  • 10m Waterproof
  • AI Editor
I’ve been using the first one extensively for 5 seasons on a tv show I’m shooting and was eager to upgrade, but this camera is absolutely useless to me unfortunately. Great thing about the first one was screen on both sides so I didn’t have to open the app all the time.
thia version can only record for 12 min I 4k on its internal battery and if you add one of the extensions, the camera isn’t waterproof anymore. Hats off to DJI for trying something different, but it’s not for me
You have alerted me to the shortcomings, thanks. I was waiting all summer for them to release the new version so I can start looking for dips in price on the original. The original is far more than adequate for my needs. I just like to hunt and "snipe" a bit of a break on pricing when I can. The original has been holding at Cdn$320 for a long time.
I think it was the review from digitaltrends that listed all the shortcomings. I’m very happy with th first one. One of mine broke down so I was planning to replace it.
A youtube reviewer said the first one dropped to $200 but I still see it at $299. If I can find it for $200 from a reputable seller I'll likely get one
