F55: New codec on FS5
Very interesting.
Wonder if anyone knows or thinks 8 bit 50MB/s MPEG2 422 is better than 10 bit 50MB/s XAVC 422?
I wouldn't think it would be "better" (fewer bits, after all), but is likely easier for a computer to crunch for fast-turnaround edits
I always transcode my XAVC footage to ProRes before editing anyways. Be it Premiere Pro or FCP.
So are Sony implementing this expensive upgrade option just for old FCP7 users? Why would anyone pay so much for an older 8 bit codec, when you can transcode XAVC to a lossless codec like ProRes :Drogar-Shock(DBG):
Transcoding takes time and requires a Mac computer for Prores. Some editos only work with XDCam style media. I had to shoot a show in MPEG422 because the guy that was doing the edit rejected the XAVC test files. He was okay with the MPEG files.
There's no doubt in my mind Sony are responding to requests by broadcasters for this codec for ENG/EFP producer/editor level production.
Heaping more pain on Canon in the process.
Upgrade cost 500 Euros (US $550. AU $740) ? for an 8 bit codec, when i can transcoded to 10 bit Prores - grade and then deliver to required codec.
No thanks.
Just buy a 500.00 used Apple computer and use it to transcode to Prores!
I think a lot of people seem to be missing the point.
If you work and make your living in television, there are still many, many broadcasters that want footage delivered in the MPEG 2 HD 4:2:2 50mbps codec.
As a camera operator you have to deliver your rushes in the format expected if you want to carry on working in the this industry.
Despite the introduction of the various XAVC formats and other codecs, broadcasters are notoriously slow to change their workflow. This is due to the cost to change editing and transmission equipment and set ups, etc. Therefore, MPEG 2 HD 4:2:2 50mbps is still very popular.
The majority of the time, any rushes are handed over at the end of a shoot. Therefore, there is no time to transcode them. If you do happen to take your rushes with you to send on later via FTP, Dropbox, etc then you may have time to transcode them then, depending on the deadline. But if you have a lot of rushes, this will take quite a while and often prove too time consuming.
If you don't work or make your living in broadcast television, then this optional upgrade is of no interest whatsoever.
If you do and want to use your FS5 in this medium, then you probably have no alternative but to pay for the upgrade.
Personally, I feel Sony should have included the MPEG 2 HD 4:2:2 50mbps codec when the camera was released or as a free firmware update. As far as I can remember, all its other cameras labelled XDCam have it (except the X70, I think?). Charging for this codec smacks of Sony being a bit greedy.
+1
Well said.
Even the $3200 Z150 comes with XDCAM HD422.
When I won't be grading and I don't need 4K or HFR, it is the codec of choice on all of cameras . . . except the FS5.
Even funnier is that it isn't needed for the transcode either. Just use ffmpeg.
I tried FFMPEG, but it doesn't make use of 72 threads and is slow. And.. it changes the audio from PCM to MPEG2. I've tried forcing it to rewrap the audio without transcoding but the resulting file doesn't load into Premiere.
The solution is not to use XAVC, but use an external recorder to Prores HQ. Much better quality and editing five streams of UHD, scaled to various picture in picture windows over a full frame segment, only taxes 35% of my PC's CPUs.
No problem xavc-i 4K in Resolve with fast PC. Transcoding takes too much time as I found out lately. And HD works even smoother.
