New Camera- Im not getting any sound- HELP
kbar
Hi all, I just got my cam today and in playback I dont seem to hear anything at all. No sound-
Any one got any suggestions>?
Not to mention that my camera keeps shutting off every 5-10 minutes or so.
Whats goin on here?
Re: New Camera- Im not getting any sound- HELP
Yeah, the camera will shut off every five minutes if you have a tape in it. It will not shut off while recording, just if you leave it idle in camera mode. I guess it protects incidences where the camera is left on accidently, and it protects the battery from dying.
I dont know about the audio. I dont want to be obvious, but have you tried turning up the volume (located above the lcd screen)?
All done! I figured the audio part out, and thanks kevin for the explanation on the cam turning off!
thanks!
[quote author=kbar link=board=Events;num=1095450927;start=0#2 date=09/17/04 at 13:21:36]All done! I figured the audio part out, and thanks kevin for the explanation on the cam turning off!
thanks![/quote]
Betcha ya did what I did on vacation...had it set to external mics but no external mics hooked up...
Ah, well. Silent films can be fun, too...
Dan
Hi. I've got no sound in playback either on a dvx 100. What was your solution?
check all the buttons and make sure they are set properly for audio capture when recording. I think the main thing I did was what was said earlier- I had one of the switches set to external or somehting like that.
hope this helps.
kevin
Thanks, but it seems to be something else as DV tapes recorded on the camera are fine. The tapes I'm having trouble with were recorded on a Canon xls-1 at 30p,
thanks again,pb
You don't have to let your DVX turn off itself for tape protection (I find it annoying). Just change the "Tape protect" setting to "Stanby".
Enjoy
[quote author=GenJerDan link=board=Events;num=1095450927;start=0#3 date=09/17/04 at 13:37:09]
Dan[/quote]
I just did that this weekend. I came home and I wasn't having any sound. And I said, what's wrong with this camera? Then I remembered that the previous weekend I shot with an external micro. Good I recorded the sound on my MD. But now, can you imagine synching the sound with the footage? What a f***ing nightmare.
All the best
Fidel.
