We know. We've known. Though they are at a place that they no longer really limit what I need. So, until displays and media outlets like vimeo get better, I have all the tools that reach that potential.Seriously? You're all surprised?
Sony already have the ultimate compact 8K SUPER ULTRA HD, 940fps SLO MO, ProRes RAW, camera made and collecting dust. But they will keep on releasing handicapped versions for the next 20 years to generate maximum $$$
The a7-II seems to be using the same sensor of the a7, which will probably mean that moderate amounts of aliasing and moire are still there. But an a7s-II with IBIS would be great. Probably in spring/summer 2015...
It might be the Nikon D750 sensor which has great 1080p both in crop mode and full frame. If so, I'd actually be very interested in this cam! Being able to handhold a 50mm 1.2 more than makes up for losing a stop or whatever of lowlight performance.
The cool thing is, there are now options out there for almost everything.Does anyone buy that heat argument made by all technology manufacturers? I don't. I really think it's marketing
I mean if Canon wanted to release a firmware update for the 5D to shoot 4K internal I am sure they will do it very easily, or to the 1DX and C100/300. What's stopping them is marketin reasons. Same with Sony, if the A7s can read the 4K sensor pixel by pixel, then downscale it to 1080p elegantly and compresses it to XAVC-S, then it probably would be less heat to bypass the internal heavy downscaling process, which it does now, while outputting a 4K signal via HDMI and two high quality signals to the LCD and EVF and baking in an S-LOG LUT and also recording a 720p proxy all in real time, without a touch of heat. Now the A7mk II with the same body has an entire sensor assembly that moves all the time, imagine how much heat would that generate compared to bypassing an intensive downscaling process. The LX100 is shooting 4K with a more sealed body (fixed lens), smaller size, with not heating issues. I don't even get why 4K needs more heat at all. The next A7s will most defnitely shoot 4K internally to an XAVC-S variable like the one in the AX100 or something with a little higher bit rate. And it will probably have the IBIS system and all the ergonomic changes.
