[FS: General] Never used Manfrotto Tripod MVH502A Head, 546B Legs - $450
GlimmerGhost
Never used, incredible piece of equipment for professionals but I'm a steadicam person so letting this go. Shipping included.
Tripod:
Load Capacity 44 lbs (20 kg)
Maximum Height 65.94"
Minimum Height 17.32"
Folded Length Not specified by manufacturer
Leveling Bubble/Illuminated One/No
Weight 13.89 lb (6.3 kg)
Head
Load Capacity 12.2 lb static (5.5 kg)
Counterbalance supports 8.8 lb (4 kg)
Counter Balance System Yes
Quick Release/Wedge Plate Yes, 504PLONG
Balance Plate Not specified by manufacturer
Tilt Drag Continuously adjustable from 0 to max level
Tilt Range -80° / +90°
Tilt Lock Yes
Spring Loaded Counter Balance Yes
Pan Range 360°
Pan Lock Yes
Legs
Material Aluminum
Head Attachment Fitting 75 mm ball base
Leg Stages/Sections Two
Leg Lock Type Not specified by manufacturer
Independent Leg Spread No
Spiked/Retractable Feet Yes
Center Brace Yes
your paypal info is wrong. i got this when send out money:
Sent to:grimmerghost@gmail.com*(The recipient of this payment is*Unregistered)
Hey can you please erase that? I'm no scam artist. Sorry if I made a mistake, first time using PayPal thought adding a bank automatically does that. Anyway this item is sold and ill be getting it out to you ASAP.
