Hi guys, selling a Neumann KMR82i Shotgun Microphone, one of the best shotgun mics. The mic has just been evaluated by Sennheiser (which bought Neumann years ago) and the mic is in mint condition and performs beautifully. Comes with leather pouch. Specifications: [TABLE="class: specTable"]
[TR]
[TD="class: specTopic"]Transducer[/TD]
[TD="class: specDetail"] Pressure Gradient Condenser[/TD]
[/TR]
[TR]
[TD="class: specTopic"]Polar Pattern[/TD]
[TD="class: specDetail"] Supercardioid/Lobe[/TD]
[/TR]
[TR]
[TD="class: specTopic"]Frequency Response[/TD]
[TD="class: specDetail"] 20 Hz - 20 kHz[/TD]
[/TR]
[TR]
[TD="class: specTopic"]Dynamic Range (Typical)[/TD]
[TD="class: specDetail"] 116 dB[/TD]
[/TR]
[TR]
[TD="class: specTopic"]Signal-to-Noise Ratio[/TD]
[TD="class: specDetail"] CCIR 468-3= 71 dB DIN/IEC 651= 82 dB[/TD]
[/TR]
[TR]
[TD="class: specTopic"]Maximum Input Sound Level[/TD]
[TD="class: specDetail"] Not Specified by Manufacturer[/TD]
[/TR]
[TR]
[TD="class: specTopic"]Power Requirements[/TD]
[TD="class: specDetail"] Phantom Power (48v +/-4v)[/TD]
[/TR]
[TR]
[TD="class: specTopic"]Output Impedance[/TD]
[TD="class: specDetail"] 150 Ohms[/TD]
[/TR]
[TR]
[TD="class: specTopic"]Output Connectors[/TD]
[TD="class: specDetail"] 3-Pin XLRM Type[/TD]
[/TR]
[TR]
[TD="class: specTopic"]Pad[/TD]
[TD="class: specDetail"] None[/TD]
[/TR]
[TR]
[TD="class: specTopic"]Low Frequency Roll-Off[/TD]
[TD="class: specDetail"] Between 2 kHz and 15 kHz the KMR 82 has a boost to compensate for HF transmission losses in air when recording distant sound sources. This may overemphasize any sibilance if the microphone is used close-up. Therefore, a two-position slide switch allows to select the setting that is best for balanced upper frequencies. The KMR 82 has a high-pass filter to suppress subsonic interference. The cutoff frequency may be raised to 120 Hz ( - 3 dB) with a built-in two-position slide switch.[/TD]
[/TR]
[TR]
[TD="class: specTopic"]Dimensions[/TD]
[TD="class: specDetail"] 15.5512 x .82" (395 x 21mm)[/TD]
[/TR]
[TR]
[TD="class: specTopic"]Weight[/TD]
[TD="class: specDetail"] 7.5 oz. (250 g)[/TD]
[/TR]
[/TABLE]
price: US$900.00 + shipping. Item is located in Los Angeles and can be picked up locally. - Mike
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
