Hidef1080
I hope these personal observations will be useful to a few of you out there.
I had Premiere CS3 on which I would cut HDV and standard definition and output to DVD or Windows Media HD all without any trouble whatsoever but I moved to Sony Vegas Pro and I got NEO Scene for various reasons.
Some observations:
When render AVCHD files out to WMV-HD in Vegas the images look about a close to the original MTS files as you can get and this would follow the theories about trying to stay as close to your source material as possible for the cleanness output. Vegas is fast however when working with AVCHD files the preview playback is not smooth [workable but there is shutter] and my T9500 2.53GHz processor is working hard [and getting hot]. Still not bad for native AVCHD editing on a mid-level laptop with 3 gigs of usable RAM.
NEO Scene creates a larger avi file out of my AVCHD mts file but with that I get [according to CineForm] 4:2:2 and 10 bits - all of which won't make the images look any better but you should have more to work with in post.
4::2:2 and 10 bits aside the main thing I've noticed is that the NEO clips render a little faster.
A 2 minute and 34 second clip in AVCHD took about 30 minutes to render and the same clip took about 28 minutes in NEO. I as so noticed that my CPU did not work as hard or get as hot while working with the NEO avi.
Playback in Vegas was as smooth as standard def video and believe it or not I can edit the NEO avi in Windows Movie Maker too for what is worth.
I usually need to add one point/degree/click of contrast when I work with NEO avi's in Vegas but that's just me.
I'll post some screen grabs I shot in “low light” [one 60 watt bulb] of the different formats in WMV-HD and the NEO Scene avi.
Some observations:
