Need your help
Hi Vlad, Maybe it's YouTube, but to me your whites look mostly blown - the footage looks overexposed by about two-three stops - apologies if this was the look you were going for?
a lot of your shots are over exposed causing detail on their skint to be lost. Make sure you use the filters on cam and use xebra to make sure faces arn't being washed out. Also there is a fair amount of camera shake. I recommend getting a sholderable cam or a pod. Lastly, it apears your to zoomed out in the begining shots for your lens. There appears to be black in the corners. You may have been trying to frame it that way, but if not be carefull when using that lens.
