Need recommendations for a good ENG Handheld mic
eiker_ir
So i've got a project coming up which will be a TV show where we'll need to do interviews with a handheld microphone on occasions.
I have an old mic that we did some tests with but it captures handling noise way too easily so,any recommendations? i'm trying to keep it under $200 if possible, produces good sound (duh) and has little handling noise (important).
I've been looking at models like the Sennheiser MD42 or MD 46 and the Electro Voice RE50/B.
Any help is appreciated.
Same as I posted on the DVi forum.
The RE50 is pretty much the defacto standard reporters H/H mic in the US. (gets more airtime than Seinfeld reruns) But I'd be a proud to own and/or use either of the fine Sennheisers.. The MD42 & RE50 are omnis, whilst the MD46 is a (wide) cardioid.
AT, Beyer and Shure make excellent models as well. Plan on spending $100-250 range if buying new.
Note: If your dealing with a camera or budget recorder that typically does not a have a lot of gain available, consider a high-output model, like the RE50 N/DYM.
An omni 'condenser' H/H would generally give you a higher output as well, but they are not usually as rugged as the dynamics... Foul weather, humidity and such could be an issue with them too.
Sorry to get in late here....
Recording with the EV-50 will work fine going to a video cam, or better yet using a mixer. If you are recording to a pocket recorder like a Dr-100, you won't have enough gain. The EV is a good mic, but it is a dynamic and won't perform well with weak preamps.
Grant
Just to throw another option in here I have been doing some tests with this low cost omni capacitor mic and it performs really well and sometimes better than the beyer M58's I have, it also has plenty of gain and low handling noise and is small to hold. You do need a foam wind gag on though and it also performs better with an 80hz high pass filter in circuit.
Cheap as chips and very well made: http://www.ebay.co.uk/itm/TAKSTAR-C...nstruments_Microphones_MJ&hash=item3cc1f9e10e
