Need major help on MAC workflow with GH1.
NellieN
Ok I have the GH1
I have the following programs installed on my mac.
Final Cut Pro Version 5.1.4
Adobe Premiere Pro CS4 Version 4.0.0
iMovie HD Version 6.0.3
JES Deinterlacer Version 3.5.4
Now the only program out of the 4 that can read my GH1's 1080 AVCHD .mts files is Premiere. I can open the files in Premiere, but in-order to convert the footage in JES, I need to export them out of premiere into some kind of format. Main problem is I cant seem to figure out what format to export them out in. I mean there are 1000's of combinations? Basically all I would like to know is what settings should I use to put into JES?
When I open a .mts file in Premiere I right click on the .mts file and go to properties it tells me the footage is this...
Type: MPEG Movie
File Size: 161.2 MB
Image Size: 1920 x 1080
Pixel Depth: 32
Frame Rate: 29.97
Source Audio Format: 48000 Hz - compressed - Stereo
Project Audio Format: 48000 Hz - 32 bit floating point - Stereo
Total Duration: 00;01;29;00
Average Data Rate: 1.8 MB / second
Pixel Aspect Ratio: 1.0
How should I send this file out from premiere to Inverse telecine and make it 24p?
With fcp 5, I had success transcoding to Apple Intermediate, using Voltaic HD to do the conversion and pulldown removal. Voltaic can convert to other formats, but AI gives you the most real-time capabilities with the best quality. They have a trial version of the program so you can test it out.
If you go to fcp 6 then you can use Prores, which is even more compatible and highly recommended.
Any other codecs either suffer from lack of real-time capabilities or image quality.
Ok I have the GH1
I have FC Express, and use it as my initial 'log and transfer' from the AVCHD format to Apple Intermediate Codec (Express doesn't have the more advanced codecs...).
Once in AIC, I then use JES to deinterlace and do the 3:2 pulldown. Yes it creates more 'files' but I've tried editing AVCHD directly in Premiere, and my machine, the realtime Premiere processing, results in pretty crappy performance... with the AIC files Premiere seems to be happy. Express doesn't have a 24p timeline option for a sequence, so, I have used the PAL configurations for a 25 fps time line. If I want to use FC Express. Otherwise I've been 'learning' how to use Premiere.
