Got my hands on a loaner HVX 200 and FS 100 for the weekend. The dealer is (of course) closed until Monday and he doesn't know anything about the camera anyway (he's mainly a Sony guy). I would have much preferred P2 cards for the trial, but he didn't have any so this is my one and only way to test the camera before purchase.
I've read the salient manual passages numerous times but I CAN'T get the darn combo to record. The steps I've followed are these:
First, for the HVX:
- via RECORDING SETUP from main menu, set REC FORMAT P2 to 1080i/60i (stupid firestore manual just says to select an HD recording format in the quick start guide and diagrams but somewhat contradicts this online by requiring that recording format be set to either 720P/60P or 1080i/60i. I had initially set it to 1080i/30P!)
- via HVX menu 9, OTHER FUNCTIONS, set 1394 Control to "BOTH" and 1394 CMD SEL to "REC_P" (also tried the latter setting on "STOP")
For the FS 100:
- set CONTROL menu to TAPELESS
- set DV FORMATS to P2
- set HDD MODE to DVCPROHD REC
Hitting record via the main side switch on the camera or the top handle switch produces absolutely NOTHING. I can get the FS to look like it's recording if I change the control menu to LOCAL and then hit the REC button on the FS twice. I get a blinking red/record pause led on the Firestore after one hit and a steady red record led after two hits.
Problem is, even after this, I'm unable to see any MXF files on the FS when I plug it into the computer and change the HDD mode to DD DRIVE. The computer recognizes it as a storage device and displays its folder structure, which includes folders numbered 0 through 9, a folder with a bunch of numbers identifying it, but which is EMPTY, a log folder, and 4 other files. The drive size and available space in Windows explorer are identical, 93.1 GB, even after "recording" several minutes via the local control route.
What is wrong? I have a red "P2" icon with a line through it blinlking constantly in the camera LCD, obviously warning that no P2 card is installed, yet the online instructions for the FS indicate you don't have to have a P2 installed to record to the FS.
Can someone please help me figure this out while I still have some time to shoot some demo material this weekend? Any help MUCH appreciated.
First, for the HVX:
For the FS 100:
