Denniscasey
Asking a lot, but are there standard functional tests some of you run to ensure camera is functioning properly before you take it on a shoot. Or the sort of tests camera rental shops may run to test camera before sending it out with a customer—or check after a return to be sure customer did not break something? I did a forum search but did not find what I was looking for (possibly wrong key words or whatever).
Reason for question: I will be receiving new HMC40 from B&H on Monday. I trust B&H, but I am not familiar with this camera or high def file based (memory card) technology. Given this situation, when I first turn camera on if it does not seem to work I won’t know if it is something I am doing wrong (most likely the case) or I have one of those rare cases when new camera is defective. If I had some basic start up tests I could run when I first turn camera on they could help determine if operator error or faulty camera. There is also the 14 day limit I think B&H has to return defective equipment entering my thinking here.
Given all the settings this camera is capable of I don’t expect start-up tests will test for everything, but would maybe at least test major components. I am hobbyist level coming from tape based standard def with Sony VX2000.
