Need help with HVX200 focus
essad1127
Is there a way to do extreme closeups on the HVX200 without it being blurry? This is also without changing the lens. I have tried to shoot things very close and I cannot adjust the focus enough so that the image is not blurry. Is there a setting that I may be missing or do I need to change the lens entirely?
You can't change the HVX200 lens, only replace it with the same one if it would break, and still that's nothing that you could do alone.
In order to be able to come as close as possible, make shure that you are zoomed out all the way when bringing the camera really close to an object and trying to focus.
The only other tip I know that would help is to simply to zoom in on the object you're filming as much as possible, and setting the focus. That will give you a pretty close up image.
Sorry, you will have to excuse me as I am pretty new to cameras. What I meant is that we have a Letus lens that we sometimes use.
I've tried all the zoom techniques, I was just wondering if there was some sort of close-up setting that I didn't know about.
the letus isnt a lens. all it is is a device that allows you attach photo lenses to a fixed lens camcorder
my advice is go get you a macro lens (lens made for extreme closeups) to use with your letus
