Does anyone know how to remove all audio effects and EQs from an entire sequence without going through each individual clip and removing them one at a time?? Any help with this would be much appreciated. Thanks.
Hold Alt and drag from Left to Right to select all of your audio clips. This will put you into segment mode and select everything you lassoed.
Hit Remove Effect and you'll remove the effect on every clip that you selected (make sure you don't have video tracks selected if you plan on keeping your video effects).
