Need help in correcting color for first shoot in a restaurant
dalethompson
I'm about to shoot my first scene of a new documentary in a restaurant this weekend. I've got the audio figured out now but the room of the restaurant is giving me fits.
The walls are a terra cotta color with a black ceiling. There are wood (and glass) wine cabinets around three walls (except for the one wall, which is the terra cotta color). The main table in this private room is light stain (sand color) and glossy on top.
I've done two test shoots on this room and after the first one, I decided to change the six potlights in the ceiling to another bulb (a GE reveal bulb, 100W instead of the 40W regular bulbs they had in there). It made a huge difference in terms of available light and I was sure it would be OK for filming. Well, I just reviewed the test shots from tonight and they are coming back with a reddish/orange tint to them. I'm including one pic from the test shots to show this.
I'm frustrated because I'm not sure what I'm doing wrong in terms of settings. The skin tone on my wife (in the pic) is way off and I hate the reddish/orange hue in the footage. If I try to add more light from an external source, I run the risk of having it bounce off the glass in the room. I want to think I could correct this somehow in FCP too but I also don't want to chance this either, just in case. Besides, I want to learn from this and try to fix it without the help of a computer.
In case anyone is wondering, I'm shooting in 720/24p and the scene file was cine-v (I believe, although, it's late at night and I'm getting tired). I had to open up the iris all the way and it was bouncing between open and 2.0.
Should I use the gain (I had it switched to Low) to brighten things up? Or should I try to adjust the white balance manually and hope it takes away some of that craptacular orange hue?
Any comments/suggestions/hints or tips & tricks are always welcome.
TIA,
Dale
add a lot of light. try softboxes for the glass. I personally would not use gain, take the time to get your shot as good as you can in the camera.
Not knowing your light resources, I would hang a china ball or softbox on the ceiling to raise the overall ambient light. White balance manually and then at the head of the shot place a chip chart with at least black, gray, and white. This will aid in color balancing the shot in post.
Trying replacing your bulbs with the screw in fluorescents rated at 6500.
Or cover the ceiling in white foam core and bounce a couple of 2 K's.
Or... Pay me large sums of money to DP. :dankk2:
Thanks Dick and Jim for your suggestions.
After reading Barry's book, I realize now I can't use gain when shooting in 720/24p (I was tired last night and must've missed that in the book). I'll a little bit worried that the scene is going to end up dark and with lots of noise.
I'm going to try to add more light but I'm thinking it's probably me who messed up everything in the settings. I added much more light to the room (the lights I added went from 160W (two of the potlights had bulbs which were burnt out) to 600W and readjusted the other lights in the room to make a more even lighting effect. Doesn't sound like a lot but in terms of the room, it looks much, much brighter than it did the first time I was there.
As far as other lighting, man, I'd love to have more of it but that may be a problem right now in terms of securing some and finding out where to put it in the room. I'll check around though, I may be able to rent out a nice LED light panel for tonight. Maybe I should get some more bulbs which are higher rated in terms of K's.
Here's a thought too: If they use a white tablecloth (which I think they will since the rest of the tables in the restaurant are covered), would that be a good or bad thing? It would certainly take away that deadly shine from the table but would the white absorb light from up above in a positive or negative way?
I'm going to try more tests with the white balance... perhaps I adjusted it wrong too.
Thanks for the help,
Dale
P.S. Jim, I'd love help here in Toronto and if I could pay for you, I do believe it would be a good thing :)
Dale,
I don't know whether this is part of the problem, but when you do your white balance, remember that it cannot be adjusted if the Auto Tracking White (ATW) function is turned on. Also, are you using an AWB preset on the camera?
Nexis:
hmmmm, very interesting point.
I just checked and the ATB is turned to off.
The ATW was switched to on.
You may have helped to pinpoint the problem with this :)
I'm going to do another test shoot in another hour, so I will be able to find out soon enough if this will make all the difference in the world (along with the other changes I adjusted along the way).
Thanks so much for this... I'll let you know how it turned out. I'll buy you a beer if you fixed this for me :)
-Dale
Dale - It may look to your eye like a great improvement, but what does your camera say? A white table cloth will definitely help. If you get different bulbs make sure they are daylight balanced, color temp of 5600 or higher, the more watts the better.
I tried to do a little color adjustment but the image you uploaded is rather small to be very effective. But here it is anyway.
Jim:
Oddly enough, the test shot (from what I could see) looks remarkably like what I just saw with my own eyes and through the camera just now.
I did another test shot (thank goodness the restaurant is down the street from me) and after all the settings were changed, I must say, what a difference!
Thanks so much for helping me out, I really do appreciate it!
Nexis:
I did what you said... what kind of beer do you drink lol?
Everything looks great in my test shots!!!
Thanks again,
Dale
Nexis:
Thanks again
Awesome! Glad to hear it, and very glad to be of help!
PM me some time - I'm partial to Stella Artois (bottle). I even have a story about it for you if you're ever interested.
Cheers mate.
Nexis
Nexis:
I like Stella as well but, generally, anything not watered down is good for me too :)
For sure, if we meet up, tell me the story about it.
Is there a Toronto chapter of the DVX group? If not, perhaps it can be organized or something, I think it would be good to meet other people in Toronto regarding film.
Here are a couple of pics from Friday night. In the end, the settings you suggested made the difference I believe. I'm glad I replaced the lights too, made such a huge difference as well. The restaurant was quieter than usual too (it was Halloween), so this was a good thing in terms of background noise for the audio. I ended up running a Rode mic under the length of the table (12 feet) and taped it up right near me. I was worried the audio was going to be muffled or even that it would pick up too much if I left it near the camera. For $20, a cheap XLR cable solved this potential problem.
I'm learning how to edit in Final Cut Pro Studio, so I'm taking my time in putting everything together right now. Maybe in a little bit I will be able to start posting snippets either on here or another external site (with links).
Thanks again for your help, much appreciated.
-Dale
P.S. Yes, that's me in the pics, I tested myself out in the end as my wife was busy running around getting things ready for everyone
That's great that everything worked out. It'd be cool to meet for a beer to discuss film related stuff. PM me if you're interested - my schedule is fairly flexible.
I live downtown (Richmond and Spadina), so there's plenty of places to catch a drink.
Cheers!
