Need Audio Recording Refresher
Its been a while since I used my 100A. As a result, I'm starting from square one. I've noticed that in order to play back audio that was recorded via an external Shure SM11 mic (using Input 2), I need to flip both Channel 1 and 2 switches back to Int(L) and Int(R) settings. Initially, I had both set to the Input 2 positions.
Is the latter normal? I apologize for asking such a dumb question.
I've also noticed recorded audio occassionally will not play back. When this happens, pressing the stop button and trying again will make things work. I can say that the audio indications in the LCD monitor look fine. So, for some reason, play back occassionally is a problem.
