jambredz
Ok i got this tripod and its my first "real" Tripod ...i had a very smooth one before but it was a cheapie. This Libec has alot of pro features including a counter balance system that supports 10 -22lbs. As i understand it (maybe mistakenly ??) when balanced correctly you should be able to tilt the head and be able to let go of the pan handle and the tripod head should stay in that position on any drag setting including 0 ...correct?? Well i'm having no luck balancing this thing.
My 7d rig weighs about 12-14 lbs so its in the range. Its there a step by step process to doing this?
