Neat Video Profiles for HMC
Exact
Sorry if this has been asked and answered but the search system crapped out on me and I kept getting errors....
I've been playing with Neat Video on footage taken using the HMC151 in a very dark (Disco) environment using 12bd gain and a little gamma change in FCP (which of course makes the noise worse) to make it a little more viewable. I've been *really* impressed by the results - although not so impressed by the time taken to render - even on an 8 core Mac using the multi-core aware settings. This would be a serious over night render for more than just a few minutes of footage!
Anyway.... has any one taken the time to produce Neat Video (Noise Reduction) profiles for their HMC 15x? Did you just do it for 0db, 6db and 12db gain settings or was it more involved than that?
If I am shooting with a 3 camera setup (3 identical HMCs) do I need profiles for each individual device or will one profile at each of the gain settings normally do the job OK for all three sources? I seem to recall still cameras being different enough that they benefited from their own profiles.
Any feedback would be appreciated.
Something is wrong if the renders are taking that long. Are you using the plugin or standalone version of Neat video.? I have quick renders on a low spec Core duo.
I do a new manual profile for each clip.
Cheers Rambo
Cheers Rambo
I'm using NeatVideo Pro as a plugin to Final Cut Pro (6) using high quality high resolution settings on 1080/50i footage. It's taking about 8 times 'real time' to render the final output on these clips.
What do you do if there scene does not allow you to create a profile because there are no large enough areas? I was assuming this is where a custom profile would be the most useful.
