1) If you have the money, I definitively second that. If you take care of them, they will last long enough to be cost-efective.Buy the best you can afford.
Are you sure you need them?
For outside shooting, I'd say it's pretty needed. Shooting with up to f/22 aperture and ISO100 won't help much on a bright sunny day, you'll still have an overexposed picture.But although I'm not "sure" that I need them, I definitely see advantages of having them for outside shoots. Since I'm planning for one, I was asking the question.
Forget Tiffens (they get progressively more greenish in tint as you go higher in ND) and get Schneider ND filters.
The best IRND right now for matte box usage is Mitomo's True ND.
The Cavision glass ones gets a little bit blueish when stacked, but nothing I can't correct in post. So for the price (~65$/pc) I'm happy with them.
Wow, those Mitomos look sweet but are really expensive...The best IRND right now for matte box usage is Mitomo's True ND. Otherwise, if you can deal with 82mm or less (and there are 82mm to 4x4 adapters for matte box usage as well), Hoya's ProND is the best (more strengths, cheaper, and very very similar).
I was thinking of upgrading from my cheap Tiffens, to the more expensive Tiffen IR/ND kit. At $120 each, the Hoyas could be in my budget too, if I don't get a full set (currently I have 1,2,3,4-stop filters, and 90% of the time I just use the 2-stop and the 4-stop, alone or stacked together). Are they clearly better than the Tiffen IR/ND?
