I'm doing a show for The National Geographic Channel this summer and I'm hoping to use the HPX500. I have a Red on the way but I'd rather go with a reliable and tested camera package for most the this shoot. These are the tech specs they require for 720p cameras. I think the HPX500 satisfies the requirements. Am I right?
Pickup Device: 3-chip 2/3 inch FIT CCD (16:9)
Aspect Ratio: 16:9
Frame Rates: 59.94P, 29.97P and 24P
Picture Elements: 1 million pixels
Gain Selection: -3, 0, 3 6 and 12 dB
Sensitivity: f 10 at 2000 lux (3200 k, 89.9% reflectance)
ClearScan Selection: 60.1 ~ 7000Hz
Extended ClearScan: 30.4 ~ 58.3Hz
S/N Ratio: 54dB (HD output)
Horizontal Resolution: 700 TV lines/ph
Registration: Within 0.02% all zones (without lens)
Modulation Depth: 45% at 800 TV lines/ph (27.5Mhz in HDTV)
Compression Ratio: 4:2:2 In and Out
Shutter speed selection: 1/100, 1/125, 1/250, 1/500, 1/1000, 1/2000 (s)
Dynamic range (1080/60i mode): 600%
Frequency response: Within ±0.5 dB, 10 to 25 MHz ... Within ±1.0 dB, 25 to 30 MHz
Quantization: 10 bit
Thanks for any feedback!
-Tom
Aspect Ratio: 16:9
-Tom
