Gopher_Greene
IS the 16GB cards going to be introduced at NAB? If so will we see a price drop?
bilgami said:If all i wanted to shoot was dvcpro50/24p what size card would get me atleast 30 min? the 16gig or higher? I was looking at the p2 store AJ-PCS060G it says it holds up to 15 4gig p2 cards. if the 4gig holds 8min of dvc50 would that be 120 min of dvc50 that the p2 store can hold am i correct in estimation?
pjg1872 said:The P2 store is not worth the money. I used it last week for a few days on an indy feature I was camera operating on.
pjg1872 said:First off, there is no digital display. All you get is little lights that are ambiguous at best. The info available from Panasonic is sort of convoluted regarding the unit. One instance is it doesn't tell you about formatting the unit for PC/mac in the manual (you must look other places). My phone can give me more info than that thing about what's on it.
pjg1872 said:Next, the unit doesn't have a fire wire 800 or 400 out. Just usb2.
pjg1872 said:Also, when you drop a p2 card onto the drive it saves it as "noname". If you save 10 p2 cards to the drive, ten "noname" icons show up on the desktop of your computer to import. They all have the same origination date too. So best of luck disseminating where the info is to guarantee you've got it all as you transfer files. This crappie system lost us half a day because the AC was moving alias files instead of actual files.
pjg1872 said:And using the p2 store with a mac is truly a harrowing experience onset. There isn't a mac viewer (like they have for the pc) to quickly check footage. Everything has to be dropped into final cut in a very slow work flow, and losing all that exciting metadata. Frankly from my point of view, if you can't verify the footage is really on the harddrive and intact, you can't format the p2 store.
pjg1872 said:So, as you sit around wasting your shooting day, while the computer renders your footage before you format your cards and p2 store, remember, I told ya to avoid that thing. Spend your money on a used 1 ghz powerbook g4 and upgrade the chip to almost 2ghz. Drop your cards directly to a portable 1 terra mirrored raid enclosure.
