My Summer 2011 DP Reel :)
Ok you have a really good and varied reel that should get you good work!
My only 2 comments which I think would improve your reel are: take out all the shots of the woman in that dress running down the green field like in 1:14
and on most scenes I think you should bring the color grading down a notch. Not completely, just a little bit less stylized.
good luck!
Have an upcoming feature you need one for?! Maybe we can work something out.
/End thread hi-jack.
Seriously, your work is gorgeous as usual. If this is your "Summer Reel", I can't wait for your "Fall and Winter" one!
Kegan
Don't forget to put birds in it. :-)
- Greg
With my luck, they probably will be :)
I have this project I'm currently working on where a couple is walking down the pair and a bird flys by right above them and lands perfectly right smack in between them. Perfect. I can't show it yet because of NDA but it will be in the next iteration of my reel :)
I've looked at your previous stuff which had a lot of the same material. The biggest improvement I see is that you finally get the importance of the score. Everything is always ten times better when all senses are in play and you use all of the elements to reinforce what your communicating.
That's funny, I've had the same score on my reel for almost 3 years...
