evinsky
I decided to do my own res test using the HVX in 1080 24P mode. I suspected the HVX might be resolving a little more than Adam Wilt gave it credit for, mostly because of the condition and speed of the test. I have a Century Optics res test, not quite as accurate as the Trumpets but good enough for my uses.
On this chart "E" is 576 Lph and "D" is 640 Lph "C" is 896 Lph.
From my observations the HVX easily resolves 600+ LPH and on fine (as opposed to acute) detail, like texture and skin, up to 640 where moire becomes visible. There may be even more fine detail rendition beyond 640 but I can't measure it on this chart.
If you understand optics then you realize the difference between acute resolution and fine detail resolution. You need a good balance of both. This camera probably resolves about twice as much as a DVX. A little more than half a Cinealta and about 3/4 a Varicam.
Details.
10mm, F4, Sharpness -7, 5 feet from target.
Details.
