My hvx 200 has creeping problems Help
When I zoom in on manual or auto it creeps back slowly, zooming back all the way with out stopping.
I was told this is called creeping. How can it be fixed without having to send it in to the prison repair shop.
And or what is causing this?
Is there a part that can be replaced?
I just received an hvx 200 that I purchased used. It also creeps back to a wide shot when the servo is engaged.:undecided It appears to be about mid-range on the onboard rocker. It stays in place when set to manual though. Could it be it just needs cleaning? Or is there some sort of 'reset' to center out the rocker range?
As i previously mentioned, it is a problem with the Servo. From my experience when I see one in the shop either there is corrosion on the boards, or some sort of blown ic or "fuse". It is repairable. I would gladly share more info off thread for anyone interested.
