My HMC151 Broke :(
igetcha
hi all,
my beloved camera became faulty today and i dont have a clue how it could have happened.
i was recording a client and then took out my SD card to transfer the footage on to my laptop..............everything was fine at this stage.
i then put the card back in and went to start recording again but noticed that an exclamation mark was showing on the screen. as my battery was running low i assumed it was because of that so i changed the battery to a fully charged one but the exclamation mark was still flashing on the screen.
so i thought to press the record button and see what happens..............once pressing record a message displayed on the screen saying "write protected" even though i knew i had not slid the protection tab on the SD card!
i went to remove the card to double check that i had not protected it by accident but the card would only come out half way. no matter how much coaxing i gave it i could feel that something on the left hand side was trapping the card in its place. in the end i had to give it a bit of a firm yank which then finally released the card.
however, the card had been ripped all along the left hand side and there was now a gap where the card protect tab used to be.........that section of the card was completely ripped out!
i can now no longer put any cards in the memory card slot (not that i really want to risk damaging any more cards!)
if i use a torch to view inside the memory card slot i can see a small piece of metal that hangs down from the top on the left hand side. im pretty certain that caused the problem!
i just cant figure out how the hell one minute the memory card slot is fine and then just 5 minutes later (with the camera on a tripod and no one going anywhere near it!) it suddenly gains a random piece of metal that likes to chew up SD cards! :(
anyone else heard of anyone having this problem??
ive contacted panasonic support via their support website and it says they aim for a 5 day turn around on repairs which i thought was pretty good..........just hope they are true to their word.
im gutted! :(
Sorry to hear about your problem. I know you must be completely aggravated by this.
So far my card slot has been fine. But I have had similar experience with a card reader once. It was mostly the way my card was made, It was cheaper made card and it got stuck. But also, when I pulled it out of the reader, it came out at a slight angle and messed up the reader.
I can only assume that maybe my issue with my old card reader is possibly what happened with your HMC.
Hope Panasonic can help you out.
hi mate,
the card i used was a pretty much brand new class 10 SanDisk EXTREME 30MB/s..........which i think is one of the most expensive cards available! lol
at least one good thing to come out of this is that i will be able to let people know how good the panasonic support service is :)
hi mate,
panasonics courier should have been here today to pick up the camera, but as yet there is no sign of them :(
