My Card Is jam in the slot can not come out , need advise
dhardjono
i try to pull out my sandisk extreme card to change it pop ot little bit than i try to pull out and there some thing blocking it , most likely the safety nob thing
Can any body give me some advise how to take it out with out breaking the slot?
thks
I was able to take out my sd card with a thin plastic same size as the sd card and slip it in from the top all the way and pull it out with the sd card,
It was the broken safety tab
GOT THE TIP FROM GH2 FORUM - FROM KAKALONG THANKS KAKALONG
Hi, guys,
I just removed my card out of the camera, after reading many useful posts and one day effort.
The approach is really simple. Find a plastic thin sheet; cut a strip with a width approximately equal to your sd card; insert the strip into the slot; you will find you can easily pull out the card.
The plastic sheet can be a plastic cover of some toys or electronics.
I attached a pic for your information. Good luck!
