.MXF Storage question, please help
ax_filmer
We just bought 2 HVX200s and 4 4gig P2 cards...and im going on location to shoot...now my question is, can i just pull the .MXF files to a harddrive and convert them later?
I have shot some things on the P2 drives, but i want to clear them before i go back on location.
Thanks for your time,
AX
AX
Yes, It's on page 84 in your HVX manuel. Keep in mind that you can only make 15 transfers. The HVX makes a new partition on the hard drive for each P2 card transfer. Most hard drives only allow 15 partitions. Since you have 4 gig cards you only need a 80 gig hard drive (4gig x 15 partitions plus 20 gigs for buffer). Anything bigger than that is a wast of money. Unless of course you happen to have a bigger drive just laying around.
Ok thanks,
My last question is Dubbing to a DV tape off of P2. If i dub the 720 30pn (60fps) to a mini DV. Will it caputure the progressive 60fps? Or should i just convert the .mxf files to premiere pro 2
ax_filmer said:
Ok thanks,
No. It will only record what DV25 can handle. 60P is twice the info as 60i and DV25 can't handle it.
I am a FCP guy so you're gonna' have to refer to the forum concerning MXF workflow in Premier Pro.
