MULTICAM synchronization problem
lacyko
Hellouu!!
This is my first topic on that forum!! I like it!
I learnt how to use MULTI CAMERA mode in AVid xpress pro. But I have problem now with video and avdio synchronization for example from two camcorders.
Problem is, because I cant give SEQUENCES in group. I can give in group just MASTER CLIPS. I can synchronize first camcorder and second camcoreder in sequences. But then I can´t convert SEQUENCEs in MASTER CLIP.
I know just a longer way for do that conversation (If you export sequence on desktop and then import movie back in AVID it has been changed in MASTER CLIP form).
But I need to do that easier and shortly!
Please can anybody help me How to do that!!!
AND SORY BECAUSE OF MY ENGLISH!!! IT IS VERYYY BAD!! SRY:2vrolijk_08:
I'm not at my Avid at the moment, so if this doesn't help you I'll post a more detailed answer later.
Open your master clips and mark an in-point at the beginning of each clip at the same moment in time. Meaning that your in-points are synchronized. Then when you group those two master clips one of the options when grouping is "sync by in-point." Then your group clip will be synced together and you can edit with the multicam controls.
Heyy!!
It works very good!! Thank you so much!!
I cant belive, i didn´t see that before!!
Thank you so much!!
