M. Gilden
Canon DSLR Moderator
Hey guys- just wanted to share this idea I was playing with for using various batteries I have lying around to power my little Sony cameras.
Its based around those little standard Chinese battery chargers that have different tops for each kind of battery:
I realized that I happen to have a bunch of these, at least one for each type of battery in my arsenal (Canon, Panasonic, Sony, etc). And they're actually all identical, aside from the top part, which is actually just a plastic plate for each specific battery type which can be popped off and swapped with other charging bases. I started thinking- instead of buying a battery plate for each type of battery I'd want to use, why don't I take one of these extra charging bases I have, gut it out and turn THAT into a battery plate? Then I could simply replace the top part with whatever battery type I happen to have available at the moment. Heck, these things are so cheap, even if you only intend to use one type of battery, it's still more cost effective than other battery plates.
I mentioned this on some Filmmaking groups and got a lot of questions and requests to explain in more detail, so I threw together the following video. Decided to share with you guys and see what you think too.
Sorry the video was rushed, I should have spent more time to open it up and show how it works instead of rambling on. But you get the idea.
