MTF Adapter and Lenses
LeavingTheCandy
Mine has FINALLY arrived. I would like to get some glass to cover the wide end of range since I have the Sony's and an awesome 200mm/f2.
I'd like to get into the 18-24 range and something in the 135mm range. I'd prefer f2 or faster.
Any suggestions?
Thanks.
Not much different than using it on a Canon 7D or T2i, which are 1.6x. And exactly the same as it would be using those lenses on a film movie camera.
I have a set of seven Nikon primes (the widest 17mm). 17mm can cover an entire room. More than that and you start looking at serious barrel distortion. Nikon also makes an 18mm f2.8.
Another option for you is the Tonika 11-16mm f2.8. At 16mm it has little distortion.
The other thing is the really wide lenses don't seem to come at F2.0 very often. Most are F3.5 with only a few at F2.8
Yeah, but the MTF adapter introduces a 1.5x multiplier. So it's a different lens game.
This isn't exactly true. I own the MTF F3/Nikon adapter, and there is no optical (glass) element, it's merely an open metal spacer that mounts the Nikon lenses as the correct flange distance from the image plane.
The notice about "magnification" is for people who have been using their 35mm lenses on fullframe stills cameras.
Any 24mm lens, whether it's Nikon, Canon, or PL mount, will have the same field of view on the PMW-F3.
Yeah, I wish they wouldn't put 'multiplier' in the ad. Its misleading. It just depends on the sensor size not the adapter. Mike Tapa should have said crop size.
If you are looking for wide angle zooms, two common ones that are rectinlinear throughout their zoom range and are quite fast are the aformentioned Tokina 11-16 f2.8 and the Nikon 17-35 f2.8. The Nikon is a workhorse lens for stills pro shooters so finding them used is possible but a bit tricky these days. I would recommned both. The Nikon will probably see more use on the camera but if you do wide shooting, I would consider both essential.
[Not on Full Frame.] On other DSLRs, approximately. It depends on which DSLR as there are several sensor sizes. The S35 is 1.5 crop factor. The Canon APS-C is 1.6 crop factor. Very little difference. The S35 is just a little bigger all the way around.
Cool...yes, that multiplier thing set me for a spin. So, a 17mm on a full-frame DSRL will have the same crop as the F3?
Thanks.
No, the 23.6mm wide imaging area of the F3 is smaller than the 36mm wide imaging area of a Full Frame DSLR like a 5Dmk2, so if you put the the same lens on both cameras, the F3 will capture a smaller "cropped" portion of the full image circle than the FF35 DSLR's "cropped" area of that same lens image circle.
