Move a Final Cut Pro X Project to Final Cut Pro 7 - New Utility Released
David Saraceno
Moderator
Staff member
Just saw this available now at the Apple Store.
http://assistedediting.intelligentassistance.com/Xto7/
Xto7 for Final Cut Pro (previously named Project Xto7) - an import translator for Final Cut Pro 7 - translates the brand new Final Cut Pro X Project XML (fcpxml) and converts it to Sequence XML for import into Final Cut Pro 7 or other applications.
Your Final Cut Pro Sequence XML is ready for:
Color
Final Cut Server
Premiere Pro and then dynamic link to
After Effects
Soundbooth
Encore (for real Blu-ray authoring)
Final Cut Pro 7 and then to
Soundtrack Pro
Motion 4
OMF output for ProTools, etc.
EDL export
Print to tape and Edit to tape
other Final Cut Pro 7 XML workflow tools (such as Sequence Clip Reporter for stock footage and music cue sheet reports).
Already working is a Final Cut Pro X Project with:
Titles at the start and end;
a mixture of primary storyline and connected clips;
a mix of active and inactive clips;
large numbers of J and L cuts;
to-do markers and regular markers;
spot audio effects; and
cross-dissolve transitions.
any plugin that comes out to benefit FCPX/FCP7 is appreciated. wish they would get here faster though. need to read some of the reviews about this and hope to hear good feedback.
thanks for the heads up!
david
