drboffa
Those of you using a Zacuto Gratical Eye (or similar) on your FX6, how are you mounting it?
I've been mounting it via the stock LCD arm (along with the stock LCD). This arrangement is fine, if not perfect. (But maybe there is no perfect solution.)
Is anyone using the Zacuto top plate, for example?
I think my ideal setup would have the stock LCD and the Zacuto mounted independently, so I could swap the latter in/out easily as needed. But maybe that's asking a bit much...
