GH2 Mounting a microphone to 15mm rods
I wouldn't expect the plastic tip of the screw will give you enough grip to prevent rotation. I also be a bit concerned that the uncircular clamp might scratch the rods, making it more difficult to slide things on and off. kenkyusha's ebay item looked promising, but I prefer accessory mounting clamps that span the two rods.
I've got one of these:
http://www.bhphotovideo.com/c/produ..._9041670_9041670_4_2_10_7cm_Articulating.html
While it's not that cheap ($65) it's really solid and useful for all sorts of stuff. I often put a shock mount on it (need an adapter or bushing if the shock mount has a 3/8 hole).
