You want a motorised Dana style (2xspeedrail/scaffold) IMO
Meet the gaffer had a vid a couple of years ago.
The best part is, you can buy a Dana Dolly knock off, or you can rent a Dana. They are so cheap to rent. And easy to DIY as well. The emotive base motorized unit for the Dana is around $500 I think. and then you can make the slider as long as you want. SO versatile.
https://www.adorama.com/emst4mcdd.h...5vgCHEAQYAiABEgK9M_D_BwE&utm_source=adl-gbase
See if anyone local has it available.
Yes it only works with the ST4.
But how useful is a motorized slider without some sort of pan and tilt auto head?
You're right but ideally you'd be able to use the motorized slider with whatever set up you like e.g. ronin 2 without being forced to pay for and use their head.
Sorry. I think you misunderstood my question. Is still useful a motorized slider without pan and tilt head? What shooting situations would it be useful for example? I'm fine with a slider without pan and tilt head as they are MUCH cheaper. But I'm wondering how useful they are.
Probably not that useful unless you're happy with the camera moving along a single axis.
not quite 2 person.
does one need pan and tilt for it to be worthwhile?
well id say to serve a director or DP basically yes
to make ones own projects then only one can decide
my own rig is more stable in slide and pan only mode as the tilt arm can vibrate.
I feel pan and slide without a tilt is useful, I do have a bowl though - so can pan and slide with the camera pointed at many angles including fixed tilts
this shot uses both pan and tilt to keep the logo in a logical place - af is also a major player in this shot. A remote focus can work for less extreme shots. https://vimeo.com/315748218
I think that one can push and oprate and its simpler than programming something esp when following inconsisten human actors, except in the situation of match cuts and fades (repeated vfx slides)
The implication was that it is a two person thread. Not quite true.
.37 you can see vfx slide - as I stack up the pencils
https://vimeo.com/347051059
Man that is a totally different thing. Motion control and a motorized slider serve different needs I think. Yes with something like FS7 probably not big deal to push and operate. But try this with a F35 set up or F65, alexa etc. Camera rig alone weighs 5x a FS7 at least. Not so easy anymore. Inconsistent actors but I guess motorized slider can be moved manually too? It's just a belt that drives them right? And what about inconsistent pushing? Eliminated by a motorized slider. And sorry but for a while it was only Rob and I back and forth in the thread. Good that you came back.![]()
