More slow mo questions
boulder
I shot at 720/60 fps 125 shutter speed. I put it in the timeline and put playback speed to .4 and disable resample...looks great. Now I put the playback at .25 and it is slower and still seems to look good, is there anything I'm missing as to why .25 would look as good as .4? Then I try to go even slower but it seems the limit is .25, any way around this? Anyway to make a clip go even slower?
Well, my motto is: if it looks good, then it looks good :)
Re speed, Vegas limits you to speeding up or down by 4 times (i.e. anywhere between 25% and 400%). If you want more/less than that, render at the max/min rate then import the output and speed it up or slow it down again (and again, as required).
Yeah I did that but you can really see the stutter of the missing frames that way. Thanks.
David i know i asked this before, but im still not understanding 100%, srry to ask again..if i have the same file that boulder has 720 60p ss 1/125 (also trying to slow it down in vegas) , where my final render is 23.97 ..ok should my project property be 59.99 720 (what it was shot at) or should i keep it 23.97 720 (like my render result) ,does it matter even?srry to ask this again..
