More powerful alternative to Sennheiser EW112 / 100 G3 Sets?
Ed Ding
Hi
I am looking for a pair of wireless transmitters and/or receivers that are (way) more powerful than those nasty Sennheiser EW122 / G3
A distance of 50-100m should be possible (in the mountains).
Any ideas for (shipping right now) alternatives?
Thanks a lot
PS: Any experience with the new Sennheiser AVX or the MIPROs?
Did you have a budget in mind?
Your G3 series puts out 30mW. You could go up to the Sennheiser 2000 series which would give you up to 100mw. Or if you had the money you could get a Lectrosonic setup that would do up to 250mW.
It also has to do with what country you are in and their regulations on how powerful a transmitter you cam run.
All the best!
Dave
Thanks for the tip with the Sennheiser 2000 - didnt know them. They are OK pricewise and available in Europe. Lectrosonics not it seems...though they look great. Don't care about regulations though since they will be used in wilderness.
Thanks, that sorted it out :)
If you are going to be that far away, then the amplified directional antennae kits would be of value. Not sure if you can connect them to the portable receiver (probably not), but you could buy the rack mount receiver and then run those antennae.
Or go with Lectrosonics, but if the limit is 50mw then they won't be a lot better. Over in the USA you can get them with more power.
I suspect you have other issues.. i.e.; "those nasty Sennheiser EW122 / G3". A properly set-up G3 should easily get 100m (unobstructed line of sight). Lots of other factors can compromise range, and a higher RX power is often not the answer (according to my friends at Lectrosonics).
If you need extended range, I would look into a higher end system that can use external (high gain) antennas.
Generally, the new GHz systems are rated for far less range than a standard UHF or VHF system.
Agreed - 100m should be no problem with a standard G3.
But - have the transmitter antenna touching the body and you have an attenuation of about 70dB or so and serious range degradation - and this goes for any system from sny manufacturer.
