I was wondering this as well.... If you are shooting for the web or a standard definition broadcast is there any advantage to shooting 1080i over 720p?
Obviously on a computer screen the 1080 is a larger image but what about HDTV's? Does a video shot at 720p look significantly different than 1080i on a 1080i TV? and vice versa?
The only time I've really used 1080i to my advantage over 720 is when I zoomed in slightly to crop the image without losing quality for 720p and 480i output.
You will see a difference in the cadence of the motion, ie 60fps vs 30fps.
The image won't neccessarily be "bigger" in 1080, you will just have more resolution to work with, translation to more detail resolving power when cropping the image and zooming in in post.
I think the answer to your question depends on what your intended goal is. What's the footage going to be used for? Is your finished product SD or HD? Broadcast, web based, or for DVD.
1080i gives you more resolution (and is a bit sharper IMO), 720p 60 gives you more discrete frames and looks a lot smoother than 30P. But if your shooting a feature why would you want either (not that you are but my point is that it all depends on your final goal).
But what if you shoot 1080/60i and the final outputs needs to be broadcast AND web? Does it suffice to work in a DV NTSC sequence and change the field order before exporting?
