Barry_Green
Moderator
Regarding the JVC "motion smoothing" filter -- I asked Steve Mullen and he says that it is optional, you can disengage it. That's good news.
Common shutter angles on film cameras include 180, 172.8, 156, and 144 degrees, as well as 200 and 220.
Theoretically (and practically), they deliver similar results. One difference, however, is that because of the way a rotating disc works, different parts of the film frame will be exposed at different times. The way the disc rotates, the upper-left corner would be exposed first, and then more and more of the frame until the entire frame is exposed, and then when the shutter starts to close, the upper-left corner will be covered first, while the lower-right corner would be covered last. Theoretically it could make for a slightly different "look" when compared to a video "shutter", where the entire frame is uncovered simultaneously, then covered simultaneously.
However, as a practical matter, it appears to be basically a non-issue; I split-screened DVX footage shot against film footage, identical footage of identical subjects shot side-by-side at identical moments in time, and there was no discernible difference in motion between the film and DVX footage.
On the DVX and the VariCam, frame rate and shutter speed can be adjusted independently of each other. You can have 24p at 1/1000 if you want, or 24p at 1/24, or basically any rate between 1/24.1 and 1/250.
Now, if you run a shutter speed that's longer than the frame duration, that *will* affect frame rate. For example, if you run 24p with a shutter speed of 1/6, what will end up happening is you'll get effectively 6fps footage on your tape. Each frame is held and buffered until the full exposure is satisfied, and then written to tape, so even though it's writing 24 frames to tape, only 6 of them will be unique, it'll be duplicating five frames during the buffering process.
Film gets shot at a variety of shutter angles, which directly controls shutter speed. Anywhere from around 1/40th to 1/60th is in common use. It all looks like film, but the faster shutter speeds will render crisper motion, with more strobing, and the slower shutter speeds will give you blurrier motion, with less strobing.thisiswells said:sometimes a cinematographer will shoot a 200 degree shutter for slightly more motion blur and perhaps some may notice it, though to me it is a negligable difference from 180. I understand many Panavision films are shot this way, but I have not been on a Panavision shoot that has to confirm this.
There is a potential difference. I postulated on this on 2-pop a few years ago. Basically, in a film camera, the shutter is a rotating disc. In a video camera, the shutter is pretty much a "timer", once 1/60th of a second has gone by, the camera just stops exposing; there is no physical intervention of a physical piece that blocks the light. In a film camera, a rotating disc with a hole in it reveals the light to the film, then blocks the light. In a video camera, the CCD has pretty much an on/off switch, and the duration of how long it's "on" is the shutter speed.HOWEVER, I am not entirely convinced that todays electronic implentation of a shutter angle actually presents accurate approximation of how that shutter would function in a cine camera.
Well, yes and no. Adjusting the shutter angle doesn't change your frame rate, but changing your frame rate will change your exposure time, and changing the shutter angle will also change the exposure time. So the two are linked. A 180-degree shutter at 24fps yields an exposure time of 1/48, that same shutter at 30fps yields an exposure time of 1/60.A cine camera simply does not work that way; adjusting your shutter doesn't change your frame rate...
They don't, unless you start talking about using shutter speeds slower than the frame rate. You can set any shutter speed when running 24p, without it changing the fact that it's still running at 24p. 1/24 or 1/1000, you'll still be getting 24 frames per second, with the difference being the amount of blur (and the amount of exposure). Same as on a film camera, if you adjusted the shutter angle from 359 degrees (which is impossible) down to 5 degrees or so. It works the same (with the aforementioned difference of a rotating shutter vs. the on/off nature of a CCD).Shutter angle or shutter speed simply should not affect frame rates -or- the illusion of frame rates.
I disagree. The cameras look stroby due to the way people use them. As mentioned before, when compared against genuine film, at exactly the same shutter speed and shooting identical footage, moving the camera identically, there was no discernible difference in strobing between actual film and DVX/24p. Film strobes exactly as much as the DVX/XL2 in 24p.I think the reason why these little cameras look stroby is due to the fact there is not a proper shutter on them to allow for anything else.
Video isn't like negative film, it's like reversal film. You don't want to overexpose on video, just like you don't want to overexpose on reversal. To accomplish what you want, you'd rather want to lean towards underexposing. On reversal film, and on video, underexposing brings more saturated colors.On a negative film, single stop of over exposure does clip whites, but it enriches blacks and over saturates colors since you are in effect allowing more light to hit your film resulting in more saturated colors.
