Monitor Calibration - SMPTE Color Bar
saturos
Does anyone know a good tutorial that teaches step-by-step how to calibrate monitors by using the color bar?
Im finding difficulties because I set the contrast first then the bright... but depending what's the bright level, the contrast level will be different.
Im trying to do it on my PC Monitor. I know there's other ways and software-based calibration, but I want to learn how to do on the universal way.
Ill try to give an example:
You will have to use an SMPTE Color Bar and use chroma level to make it black and white.
http://www.greatdv.com/video/Ntscbars.gif
bright: 25% ( This is the default setting, I dont have any reference if its right or not )
contrast: 22% ( Okay, it makes that gradient and the left side isnt bright white and right site is dark gray )
bright: 18% ( now, based on the contrast I changed the bright but... if the initial bright is set different like 30%, my contrast would be set to 18%, this is the point that I want to know )
You understand what I mean? Depending the initial brightness you will have a different configuration on final calibration.
What Im doing wrong? Does anyone have a good tutorial about it?
Some tutorials that Ive read:
http://www.videouniversity.com/tvbars2.htm
http://www.seriousmagic.com/help/producttuts.cfm?prod=DVRack
http://www.greatdv.com/video/smptebars.htm
You'll never get it right on the computer. Computer monitors are just different.
Those levels you set...they're just about what I set mine to, to get it as close as I could.
Dan
Take a look at this video "Maximizing Success with DV Cameras, Part 1" on www.dv.com The video not exactly about calibration but half way trough, the guy gave us an example how to do it. Very good info...
ps. studio monitor calibration not pc
